ToLiss A321 für X-Plane 11 +12
  • December 6, 2019 at 3:44 PM
    • July 15, 2023 at 12:18 PM
    • #61
    Und jetzt auch für den A321 ein Update, für XP11 und XP12. Erst vor ein paar Tagen war es der A319.
    Hi all,
    and we can now also announce the big A321 update yet: The new version is V1.6 (build 1589) and this update brings the aircraft to the same level as our A320neo (with the respective functional difference between the two RL aircraft of course.)
    There are tons of new stuff, as you can see in the changelog:
    Major new features:
    - Apple Native M1/M2 compatibility
    - New cockpit textures
    - Animated cockpit windows, sunshades, tray tables etc.
    - Pilot models in external view
    - Full ground services suite, including animated deicing
    - ACARS Print function
    - Rework of the sound suite for all engine types
    Minor new features:
    - ISCS redesign including a scalable ISCS.
    - Retuned VLS and approach pitch
    - Retuned the pitch moment balance with extended flaps
    - Addition of 24 new C/Bs bringing the total to 161 functional C/Bs
    - Addition of Radio Altimeter failure model
    - Improved aircraft startup sequence simulating also MCDU, FWC and FMGS startup times
    - Oil temperature indication on ECAM now changes according to logic specific for the given engine type
    - Increase landing gear tire resolution for a rounder experience
    - Added console lights (XP12 only)
    - Increase number of possible simultaneous faults to 20
    - Added PRED WS OFF memo
    - Automatic reversion to arrival or departure ATIS request if regular ATIS is not available (via Hoppie network)
    - Added DDRMI failure flags in case of loss of power or invalid needle angles
    - Added different flap angles between A321CEO and A321NEO as in real life
    Bug fixes:
    - Added autopilot disconnection on manual trim.
    - Reduced minimum valid preselected speed to allow speeds below 160kts.
    - Improved mouse wheel pitch trim speed
    - Fixed a bug with the descent profile following if below transition level and QNH in MCDU and QNH on FCU don't match
    - Some improvements to the smartcopilot.cfg file
    - Fixed a bug that caused the GS Mini not to be considered with pilot selected VAPP.
    - Fixed jitter of the L/DEV and V/DEV scales that can occur under certain conditions when performing a GA during a non-precisiong approach
    - Inhibit of EGT OVERLIMIT warning following an engine shutdown due to fire
    - Brought the REV SET ECAM Caution back
    - Fixed mouse wheel function on WX Radar System switches
    - Fixed FBW behaviour in case of loss of both FAC (no reversion to direct on L/G extension)
    - Fixed FBW upmode logic to allow automatic upmode to normal law if conditions triggering a degenerated law are gone.
    - Fixed link between APU start capability and battery availability
    - Improved VLS computation in dual hydraulic cases with slats frozen in the retracted position.
    - Improved rudder authority for VMGC and Beta target
    - Fixed a crash in PDC/CPDLC messages if there are space characters in the wrong spot.
    - Fixed a bug with fuel consumption during 200NM jumps
    Enjoy!
    GK
  • FrankEDDB July 15, 2023 at 12:37 PM
    Changed the title of the thread from “ToLiss A321 für X-Plane 11” to “ToLiss A321 für X-Plane 11 +12”.
    • December 6, 2023 at 3:51 PM
    • #62
    Just a quick note that the A321 has been updated to V1.6.2 in order to get the smoothest possible experience. You can get the update via the Skunkcrafts updater or via a fresh download from the store.
    The detailled change log is:
    Changes from V1.6.1:
    New feature:
    - New ISCS option to allow rudder pedals to fully deflect the nose wheel in VR mode in XP12.
    Bug fixes:
    - Fixed logic for ELAC/SEC reversion to backup power supply
    - Changed RMP logic to maintain VHF selection during power transients
    - Fixed the ENG1 PWG engine fan blade animation (A321 neo only)
    - Fixed Cargo door animations
    - Fixed APU flap animations
    - Increased LOC reception range to values higher than the database value (which is the minimum distance with guaranteed accuracy)
    - Fixed issue with new FAC logic that could lead to loss of A/THR during power transients
    - Improved Dept RWY remapping on situation load
    - Added Overheat indication on HYD SD as appropriate
    - Updated A321LR and XLR fuel synoptic page to newer standard
    - Improved logic for MCDU class II messages
    - Maintain VHF selection in the RMPs during power tranients
    - Fixed issue with EFB TO Performance calculator when using AUTO flap setting.
    - Fixed issue with managed speed target during touch and goes.
    - Fixed issue with disappearing ISCS option for BUSS switches for A321 XLR.
    - Fixed a bug with the date on Wind and Flight plan data printouts
