X Plane crasht beim laden eines Fluges
  • Myulu
  • September 21, 2019 at 8:53 PM
  • Myulu
    Ich habe ein paar Orthos installiert und wollte mal diese austesten.
    Nur das ich auf dem Desktop lande, nachdem ich einen Flug starte...
    Das passiert mit jedem Flugzeug also auch mit Standard Flieger.
    Habe schon probiert die Orthos zu löschen - ohne Erflog...
    Anbei Teile des Logs(das komplette war zu lang..)
    Wäre dankbar für jede Hilfe:)
    Display Spoiler
    ==== CHANGING LANGUAGE TO: Deutsch. ====
    Fetching plugins for F:\X-Plane 11/Resources/plugins
    Loaded: F:\X-Plane 11/Resources/plugins/PluginAdmin/64/win.xpl (xpsdk.examples.pluginadmin).
    AviTab version 0.3.16
    Loaded: F:\X-Plane 11/Resources/plugins/AviTab/win_x64/AviTab.xpl (org.solhost.folko.avitab).
    FlyWithLua: Your system path is F:\X-Plane 11/
    FlyWithLua: System Dir: F:\X-Plane 11/
    FlyWithLua: Plugin Dir: F:\X-Plane 11/Resources/plugins/FlyWithLua
    FlyWithLua: Plugin Scripts Dir: F:\X-Plane 11/Resources/plugins/FlyWithLua/Scripts
    FlyWithLua: Plugin Internals Dir: F:\X-Plane 11/Resources/plugins/FlyWithLua/Internals/
    FlyWithLua: Plugin Modules Dir: F:\X-Plane 11/Resources/plugins/FlyWithLua/Modules/
    FlyWithLua: Plugin Scripts Quarantine Dir: F:\X-Plane 11/Resources/plugins/FlyWithLua/Scripts (Quarantine)/
    FlyWithLua: Plugin Version: 2.7.19 build Aug 7 2019 10:27:04
    Loaded: F:\X-Plane 11/Resources/plugins/FlyWithLua/64/win.xpl (CarstenLynker.FlyWithLua.NG).
    Loaded: F:\X-Plane 11/Resources/plugins/TerrainRadar/64/win.xpl (drgluck.plugins.terrain_radar).
    Initializing off screen memory.
    Initializing off screen memory complete.
    0:00:00.000 D/HID: HID Bridge Running
    0:00:01.994 I/NAVT: Airspaces are done loading async...
    0:00:04.908 E/APT: Ramp start "Standard" is located too far away (more than 6 km) from the airport NFMO
    0:00:04.908 E/APT: Ramp start "Standard" is located too far away (more than 6 km) from the airport NFFR
    0:00:04.908 I/NAVT: NavData is done loading async...
    0:00:04.908 I/NAVT: Fixes are done loading async...
    0:00:04.908 I/NAVT: Navaids are done loading async...
    0:00:04.908 I/NAVT: Airways are done loading async...
    0:00:04.908 I/NAVT: All navt data is done loading async...
    0:00:04.908 I/REN: Setting texture resolution read from prefs as 5
    0:00:04.908 I/REN: Setting |draw view indicator read from prefs as 1.
    0:00:04.908 I/REN: Setting |dim under high G-load or hypoxia read from prefs as 1.
    0:00:04.908 I/REN: Setting |draw hi-res planet textures from orbit read from prefs as 1.
    0:00:04.908 I/REN: Setting |draw forest fires and balloons read from prefs as 0.
    0:00:04.908 I/REN: Setting |draw birds and deer in nice weather read from prefs as 1.
    0:00:04.908 I/REN: Setting |draw aircraft carriers and frigates read from prefs as 1.
    0:00:04.908 I/REN: Setting |draw Aurora Borealis read from prefs as 0.
    0:00:04.908 I/REN: Setting |runways follow terrain contours read from prefs as 1.
    0:00:04.908 I/REN: Setting |3-d drawing detail read from prefs as 4.
    0:00:04.908 I/REN: Setting |water reflection detail read from prefs as 0.
    0:00:04.908 I/REN: Setting |draw parked aircraft at airports read from prefs as 0.
    0:00:04.908 I/REN: Setting compress textures to save VRAM read from prefs as 0.
    0:00:04.908 I/REN: Setting |Effects read from prefs as 3.
    0:00:04.908 I/REN: Setting |3-d shadows read from prefs as 1.
    0:00:04.908 I/REN: Setting |HDR anti-aliasing read from prefs as 2.
    0:00:04.908 I/REN: Setting |draw volumetric fog read from prefs as 1.
    0:00:04.908 I/REN: Setting |draw per pixel lighting read from prefs as 1.
    0:00:04.908 I/REN: Setting |atmospheric scattering read from prefs as 1.
    0:00:23.445 I/NET: OS has RFC 4941 Privacy Extensions for IPv6 *enabled*, using TEMPORARY IPv6 addresses
    0:00:23.445 I/NET: Ethernet (Realtek PCIe GBE Family Controller) 192.168.0.18
    0:00:23.445 I/NET: Ethernet (Realtek PCIe GBE Family Controller) fd00:bc14:1dd:fa42:60bf:a5ef:9eda:1966
    0:00:23.445 I/NET: (RakNet) Init: Successful!
    0:00:23.603 D/STM: Transitioning from state state_InitialLoading to state_QuickFlightWizard
    0:00:23.603 I/WIN: Showing subscreen Main Menu
    0:00:23.603 I/OVR: User is entering the holodeck.
    0:00:23.603 I/WIN: Opened window Primary V11 UI
    0:00:30.191 I/WIN: Showing subscreen Settings
    0:00:35.675 I/REN: Setting |3-d drawing detail set to 3.
    0:00:36.891 I/WIN: Showing subscreen Freeflight
    0:00:41.791 I/WIN: Showing subscreen FreeFlight Location Controller (Advanced)
    0:00:47.008 I/FCG: Applying changes from Flight Configuration screen
    0:00:47.008 I/FCG: Starting new flight in Aircraft/B737-800X/b738.acf at Runway 25L
    0:00:47.095 W/ATC: Found overlapping airports with overlapping controller freqs at KCEA and KIAB!
    0:00:47.095 W/ATC: Found overlapping airports with overlapping controller freqs at WSAC and WSSS!
    0:00:47.095 W/ATC: Found overlapping airports with overlapping controller freqs at RJCJ and RJCC!
    0:00:47.095 W/ATC: Found overlapping airports with overlapping controller freqs at WIPT and WIEE!
    0:00:47.095 W/ATC: Found overlapping airports with overlapping controller freqs at KNSE and KNDZ!
    0:00:47.095 W/ATC: Rewrote KAHN atc_ControllerRole_Del's freq: 133950 to 118000 for being in conflict!
    0:00:47.095 W/ATC: Rewrote KCEA atc_ControllerRole_Twr's freq: 127250 to 118025 for being in conflict!
    0:00:47.095 W/ATC: Rewrote WSAC atc_ControllerRole_Twr's freq: 118250 to 118000 for being in conflict!
    0:00:47.095 W/ATC: Rewrote RJCJ atc_ControllerRole_Del's freq: 121900 to 118000 for being in conflict!
    0:00:47.095 W/ATC: Rewrote WIPT atc_ControllerRole_Twr's freq: 118300 to 118000 for being in conflict!
    0:00:47.095 W/ATC: Rewrote KNSE atc_ControllerRole_Twr's freq: 121400 to 118000 for being in conflict!
    0:00:57.828 D/STM: Transitioning from state state_QuickFlightWizard to state_NormalLoading
    0:00:57.828 I/ACF: Loading airplane number 0 with Aircraft/B737-800X/b738.acf
    Terrain radar plugin: read settings
    Terrain radar plugin: aircraft description is "Boeing 737-800X"
    Terrain radar plugin: found aircraft "Boeing 737NG family by Zibo"
    Terrain radar plugin: menuApplySettings ---------------------------
    Fetching plugins for F:\X-Plane 11/Aircraft/B737-800X/plugins
    2019-09-21 19:19:54 librain[plugin.c:590]: This is librain (v0.10) libacfutils-3babedf
    Loaded: F:\X-Plane 11/Aircraft/B737-800X/plugins/librain.plugin/win_x64/librain.plugin.xpl (skiselkov.librain).
    load moduleLoaded: F:\X-Plane 11/Aircraft/B737-800X/plugins/xlua/64/win.xpl (com.x-plane.xlua.1.0.0r1).
    Zibomod plugin running.
    Loaded: F:\X-Plane 11/Aircraft/B737-800X/plugins/zibomod/64/win.xpl (zibomod.by.Zibo).
    Mit freundlichen Grüßen,
    David
    • September 21, 2019 at 9:30 PM
    Du kannst die Log auch als Datei hochladen, anstatt als Text. Nur Auszüge aus der Log sind immer so eine Sache, der Fehler kann ja sonstwo liegen.
    Du hast nicht zufällig Festplatten in Betrieb, die gelegentlich abgeschaltet werden? Crasht X-Plane nach dem Laden des Flugzeugs, an dem Punkt, wo es beginnt die Szenerie zu laden oder direkt beim Laden des Flugzeugs?
  • Myulu
    • September 21, 2019 at 10:13 PM
    Leider sind hier nur jpeg möglich zum uploaden....
    Sonst hätte ich die komplette Datei hochgeladen.
    Habe nun alle Plugins ausser dieser XPLM Dinger rausgeschmissen sowie alle Orthos...
    Selbes Problem...
    Es lädt bis es zum laden der Szenerie(Neue Szenerie Daten werden geladen) komm, und schmiert dann ab.
    EDIT: Also ich habe danach versucht alles noch einmal einzufügen(Orthos und Skripte) und es schien wieder zu laufen wenn auch ich beim reinzoomen starke FPS Drops hatte..
    Plötzlich, als ich die Uhrzeit umstellen wollte kam allerdings dieser Fehler und lies sich nicht wegklicken...
    Display Spoiler
    0:13:04.324 E/SYS: | Error generating path for aircraft preview.
    0:13:04.324 E/SYS: | No liveries for aircraft
    0:13:04.324 E/SYS: | Please report this to Laminar Research.
    0:13:04.324 E/SYS: | (aircraft_grid_widget.cpp:551)
    David
    • September 21, 2019 at 10:49 PM
    Starke FPS-Drops beim Reinzoomen sind normal, da steigt dann die GPU-Last ins Unermessliche.
    Hast du eine Beta-Version am laufen? Solche Fehler mit Hinweis an Laminar zu senden sind mir selten untergekommen, heute aber schon das zweite Mal. Ich mach jedenfalls geradeein Downgrade von der 11.40, da da nun die Bodendetails verloren gegangen sind und lasse das mit den betas in Zukunft ganz bleiben, ist mir zu nervig irgendwie.
  • Myulu
    • September 21, 2019 at 11:11 PM
    Lässt sich das mit dem reinzoomen irgendwie beheben?
    Nein, habe keine Beta version...
    David
    • September 22, 2019 at 6:23 PM
    Quote from Myulu
    Nicht, dass ich wüsste... das war schon immer so, dass beim Reinzoomen die GPU stark gefordert wird, speziell wenn viel Vegetation im Spiel ist oder Standard-Wolken, das muss irgendwas mit den Pixelraten bzw. der Verrechnung der Transparenzen zu tun haben.
    • September 23, 2019 at 5:43 PM
    Myulu : Der Upload von txt-Dateien bis zu 500 Kilobyte sollte jetzt möglich sein. :)
  • Myulu
    • September 24, 2019 at 6:10 PM
    Frank Vielen Dank:)
    So, angehängt habe ich jetzt mal meinen erneuten Versuch einen Flug zu laden...
    Das verdirbt mir so derart die Lust an X Plane obwohl ich die Grafik einfach liebe:love:
    Files
    Log.txt 24.59 kB – 805 Downloads
    David
  • ThomW
    • September 24, 2019 at 10:00 PM
    Der letzte Eintrag in der Log betrifft den Zibo mod. Ich würde den mal testweise entfernen
    Gruss Thomas
  • AirXgamer
    • September 25, 2019 at 11:47 PM
    Ich hatte eine Zeit lang ein ähnliches Problem: Abbruch beim Laden ohne Fehlermeldung und an verschiedensten Stellen.
    Die Lösung war einfach und simpel: Festplatte voll.
    X-Plane hätte gerne (zumindet bei meinen Setup) so 30 - 45 GB RAM zugesichert (Anzeige im Taskmanager)., bei nur ca. 20 - 30GB Platz auf der SSD und 16GB RAM war das ein Problem. Nachdem ich ca. 40GB frei geräumt hatte lud X-Plane wieder alle Flüge ohne Probleme. (Momentan liege ich mal wieder bei 15GB frei, X-Plane bricht beim Laden des Fluges ab, gerade getestet.)
    i5 6600k@4Ghz 16GB RAM GTX1060 6GB
  • Myulu
    • September 29, 2019 at 8:22 PM
    Bitte entschuldigt meine Abwesenheit,
    Schule geht nun mal X Plane 11 vor und daher hatte auch keine Zeit mich weiter damit zu beschäftigen^^
    Werde jetzt testweise mal die Zibo löschen und probieren ob es dann funktioniert.
    Meine X Plane 11 Festplatte hat 402GB Frei...
    Allerdings können meine 8GB RAM möglicherweise das Problem sein:/
    David
    • September 30, 2019 at 5:29 AM
    Quote from Myulu
    Ja das kann durchaus sein, vorallem wenn ich mir deine restliche Hardware (CPU und Grafikkarte) ansehe, solltest du da wirklich über mehr RAM nachdenken, also min. 16 GB.
    Ich hatte früher auch nur 8 GB, habe mir dann aber irgendwann u.a. für X-Plane noch ein 16 GB Kit dazu geholt, somit hab ich jetzt 24 GB RAM und damit komme ich aus. 16 GB halte ich persönlich als wirkliche Mindest-RAM, da ja oft schon durch Windows gerne mal ca. 6 GB verbraucht werden und bei 16 GB dann doch wieder nur 10 GB übrig bleiben. :)
